Whirlpool Gold wont drain
Dishwasher goes through complete cycle but wont drain. open door during dry cycle and full of water.:eek:
Remove the lower panel and where the drain hose connects to the white tube on the motor… remove hose then the white tube unscrews out and you may need to just clean out the tube, the hole on the center is just 1/4 in, compaired to the drain hose and does get blocked from time to time.. but be careful cut off power and be ready for some water…
