When I select a wash cycle the detergent cup switch instantly opens and remains jammed open buzzing. It seems like it is getting constant power.
What do I need to replace?
Thanks!
Remove the inner door panel and check all wires. If there is nothing wrong then, most likely, the problem is a bad control board.
- The part number for the control board is AP3775964
Here are the break down diagrams for the Whirlpool dishwasher Model GU1500XTLS0
