Whirlpool Gold Accubake Oven/Microwave
Model GMC275PDB6, Oct 2022
My oven can be set to say 350 degrees and start turns it on, but the oven doesnt get hot. My son used the oven clean and once that was over, it has not heated up again. Any help would be awesome. Thank you. June
Maybe check the thermal fuse.
You can see the thermal fuse linked here.
A copy:
Symptoms of a blown oven thermal fuse include:
The upper oven failing to heat or losing total heating function
Burning smells emanating from the upper oven cavity
Safety shutdown errors related to over-temperature conditions
Common causes are airflow restriction trapping heat or faulty wiring allowing overheating. Natural aging also deteriorates fuses over extended use cycles.
I hope this helps,
jeff sr.
