Whirlpool Gas oven will not heat
Brand: Whirlpool
Model Number:WFGS5030RZ0
Main Symptom: Oven will no heat
What happens & when: Oven will not heat. Replaced spark ignitor. Still will not heat. Either no electricity from stove terminal to spark ignitor terminal or control board issue. Trying to test current with multimeter, but i can not find two wires on the stove side terminal to test. How do I other wise test to see if current i getting to the ignitor (see picture)
Parts or tests already tried: Installed brand new spark ignitor
At the DSI spark board W10898291 behind the console check for voltage from the black wire to the white wire. Should be about 120v AC as long as the range is plugged in.
Then, if that’s good, start a Bake cycle and check the red wire with a white tracer to the solid white wire, again looking for 120v.
If that isn’t present then you either have a wiring issue between the DSI and the main board W11764619 or a bad main board.
If that voltage is present, unplug the range or turn it off at the breaker and disconnect the harness from the DSI board. Then take a resistance reading on the solid red and solid orange wires of the harness, should be 200Ω-240Ω resistance.
If that’s good, replace the DSI board. If that resistance value is out-of-range, replace the gas valve W10898290.
I’m also attaching the tech sheet for this model below to aid in diagnosing the issue.
tech-sheet-w11639169-revA.pdf (598.6 KB)
