It seems the belt is broken. How do I get at the motor and belt to replace it?
Take apart info is available at www.applianceaid.com When replacing the belt, put the grooved side against the drum where the old belt mark is and rout it around the pulley and motor. There is only one way to do this to get the proper tension on the belt.
