Dryer runs, but has no heat. Timer will not advance using “Automatic”. However, it will advance under “Timed”. Neither cycle has heat.
Based on some other posts, I suspect the solenoid coils. Is this correct, or should I do something else first.
Purchased the solenoid coil kit. Installed them in 10 minutes. Problem resolved.
