Brand:whirlpool Model Number:WSF26C3EXF01 Main Symptom:does not cool (which means fridge either) when set to recommended 0 degrees but works at -1 -2 -3 -4 -5 What happens & when:
All test pass in diagnostics
It would be recommended to check the thermistor to make sure that it is good. If this is good then it sounds likely that there may be an issue with the main control board.
