**Brand:**Whirlpool
**Model Number:**ED5FHAXVS02
Main Symptom: fridge won’t cool lower than 56F
Error Code (if any): no errorcodes on this model
Parts or tests already tried: New Thermostat exchanged but same result. Freezer is working fine
This issue could be an airflow issue or a defrost issue. Check to ensure the evaporator is not impacted/frozen-up. also check the airflow and fan operation.
https://www.appliancepartspros.com/repair-help/refrigerator-repair-help
Hi, thank you for this hint. I’ve checked the evaporator which is not impacted/frozen. After power on th fan blade won’t turn - after manually kicked the blade the fan was turning the blade. After retry power on/off the fan started with no problem.
After assembling back I could feel, that there is a lack/low airflow coming from the freezer into the frigde. Sometimes even if the compressor runs there is missing airflow into the fridge.
