Whirlpool Duet Steam Dryer Model WED9600TA0 throwing code F01
Brand: Whirlpool Duet Steam
Model Number: WED9600TA0
Main Symptom: F01 code has power but won’t click on and get heat going
What happens & when: you can hear it try to start but it won’t go.
Error Code (if any):F01
Already fixed washer when throwing code F21 huge back up of hair and things clogging the drain so that was able to be fixed but the dryer is showing the control panel board I could replace but I want to make sure I get correct part. I can try to sander it and get the connection again but figured this may be easier. I just need some help and making sure the right thing to get.
The control board you are looking for is WPW10141671 which has been discontinued by the manufacturer and is no longer available for purchase. The manufacturer does not list a compatible substitute or replacement part. The control board is located under the top of the dryer on the left side.
https://www.appliancepartspros.com/whirlpool-control-sahara-de-wpw10141671-ap6015706.html
