Just replaced the element. This happens every 4 or 5 years. Putting in a lint trap to see if that helps.
After replacing the element and cleaning out the dryer, the dryer works fine.
However, after running a load, the dryer will not turn. I press the button and the dryer clicks but the tub does not turn. If I allow the dryer to cool, the dryer works as expected once again.
This time, I had to replace the two sensors on the housing. The new element came with 4 sensors. I attempted to match them, one is 313093, L146.1-44.4C. The other is marked b-2 352f 1098 8318314 B2 352f. The new one has no markings.
