Whirlpool dual element cook top only heating up maybe halfway
Brand:Whirlpool
Model Number:wfes5030rz
Main Symptom:Dual element not heating up all the way
Parts or tests already tried: installed a different control switch and it does the same thing
First question, are both the inner and outer coils coming on? Are you having problems with the other elements? And finally, the infinite switch, is it the correct switch for the dual element? If neither coil is coming on, replace the element. If you are having problems with another element, it may be the voltage going to the range. If you did not use the correct infinite switch for a dual element, it will not cycle the element correctly. Some things to think about.
