Whirlpool dishwasher stuck in rinse. Water heating light is on. Water is hot, but dishwasher continues to run. Cycle completes in low energy / China, but on Normal or higher does not drain / advance.
I think it is either the hi limit or the operating thermostat.
The first failure suspect is the cycling thermostat [COLOR=#0066cc]AP3115144[/COLOR]. The hi-limit thermostat is a safety device to prevent overheating.
Here are the break down diagrams for the whirlpool dishwasher Model DU920PFGB0
Buy a meter otherwise you are guessing and so am I.
You can get a decent digital multimeter for under $20.00, you do not need fancy though it is nice if the leads are a couple feet long.
You can then check the heater for resistance (usually around 25 ohms) and the thermostats (should be 0 ohms at room temperature).
There is a good sticky on meter usage at the start of this forum
Maybe it is heating but the unit does not sense the temperature increase.
