Brand: Whirlpool Model Number:WED4815EW1 Main Symptom: Trips Breaker What happens & when: Breaker trips about 10 minutes into cycle. Doesn’t happen when on fluff air.
Coils seem to remain red hot the entire time until tripping the breaker. Want to rule out anything on the dryer before getting an electrician to look at the breakers.
Parts or tests already tried: Continuity tests on all related components seem fine.
Photos / video link: iCloud Photos - Apple iCloud
Since the dryer runs normally on Air Fluff but trips the breaker about 10 minutes into a heated cycle, you’ve already narrowed the problem down quite a bit. Air Fluff uses the motor but does not energize the heating element, so the issue is almost certainly related to the heating circuit or the electrical supply under load.
The fact that the heating element stays bright red continuously is also an important clue. On this model, the element should cycle on and off as the operating thermostat regulates drum temperature. If it never cycles off, either the dryer is overheating or the heating circuit isn’t being controlled correctly.
Here’s the order I’d recommend testing:
1. Check the Airflow (Most Common)
Restricted airflow is the most common reason a heating element stays on too long and overheats.
Disconnect the vent from the back of the dryer.
Run a heated cycle for 15–20 minutes.
If the breaker no longer trips, the vent system is restricted.
Clean the entire vent run all the way to the outside hood and make sure the outside damper opens fully.
2. Test the Cycling Thermostat
The cycling thermostat (mounted on the blower housing) is responsible for turning the heater on and off.
With power disconnected:
Remove at least one wire from the thermostat.
Measure continuity across the two large terminals.
At room temperature it should read closed (0–1 Ω).
A continuity test alone doesn’t prove it’s good because it only verifies the thermostat is closed when cold. If airflow is good and the element never cycles off during operation, the cycling thermostat is a strong suspect and is often replaced as a preventive repair.
3. Inspect the Heating Element
A heating element that has sagged and is touching the metal heater housing can overheat or remain energized when it shouldn’t.
Disconnect power and inspect the element:
Make sure the coil is centered in the housing.
Look for broken coils touching metal.
Measure resistance across the element.
It should typically measure around 8–12 Ω.
Measure from each terminal to the metal heater housing.
You should read OL (open).
Any continuity to ground means the element is shorted and must be replaced.
4. Inspect the Terminal Block
A loose or burned power cord connection can heat up under load and trip the breaker after several minutes.
Remove the rear terminal block cover and inspect for:
Burned wires
Melted plastic
Loose terminal screws
Signs of overheating
Repair any damaged terminals or replace the terminal block if needed.
5. Check the Breaker
Dryers draw around 22–25 amps while heating. A weak breaker can hold initially but trip after warming up.
If:
the vent is clear,
the heating element isn’t grounded,
the cycling thermostat is working,
and the terminal block looks good,
then the breaker or wiring becomes much more suspect.
Diagnosis Summary
Based on your symptoms, I’d rank the likely causes as:
Restricted vent causing overheating.
Failed cycling thermostat allowing the heater to stay on continuously.
Heating element partially grounded or damaged.
Loose/burned terminal block connection.
Weak 30-amp double-pole breaker or house wiring issue.
If the dryer heats normally with the vent disconnected and no longer trips the breaker, you’ve almost certainly found the problem without needing an electrician.
If it still trips with the vent disconnected, let me know:
Does it trip both poles of the breaker or only one?
Is the breaker a standard thermal-magnetic breaker or an AFCI/GFCI breaker?
Have you measured the voltage at the outlet (should be about 240 VAC across the two hot legs and 120 VAC from each hot leg to neutral)?
Those answers will help determine whether the problem is inside the dryer or in the home’s electrical system.
I have replaced the cycling thermostat and the thermal cut off kit. The outlet measures fine. No signs of an issue at the terminal block. I do notice that my breaker is a 20 amp double pole Breaker instead of 30. Could that be the cause while the dryer is running?
Yes as the Heating element cycle on it is putting too much draw on the circuit. Change it out for a properly rated breaker and see if the problem persists
