CLEANING LIGHT STILL BLINKS ON DISH WASHER AND WILL NOT GO THROUGH A WHOLE CYCLE. REPLACED BOTH DOOR SWITCHES! NOW WHAT ? SOME ONE HELP !! :mad:
This problem explained in the Whirlpool Technical Bulletin.
Try to reset the control board by initializing the service diagnostic cycle. Check the dishwasher tech sheet for the correct cycle sequence.
If it will happen again then you have to check the heating circuit for a faulty part(s).
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU2400XTPB3 | AppliancePartsPros.com
[CENTER]Thank you, Gene I pull my dishwasher out, and found that I have bad heat element and I ordered one. I think this is going to fix my dishwasher, I’am hopeing that I’ll get my heat element by monday.
again, thank you for your help!!! If this does;nt work I’ll be back here again. [/CENTER]
