Whirlpool Dishwasher
How do you test the Thermal Fuse? Should it have a resistance reading? If so, how many ohms?
Replacement parts for WHIRLPOOL GU2500XTPB6 | AppliancePartsPros.com
[COLOR=Blue]
How do you test the Thermal Fuse? Should it have a resistance reading? If so, how many ohms?[/COLOR]
Disconnect it and check with your meter, should be 0 ohms.
Note: a replacement fuse comes with a new harness and this must be installed (see parts)
