Whirlpool Dishwasher won't turn on
My did washer shut off during the cycle. I open the door and water was in the bottom of it. I took the filter off and found a piece of the rack in the bottom of the drain. Now why will my washer not turn back on?
Replacement parts for WHIRLPOOL DU1055XTPQ3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
The thermal fuse (Item 6 in Section 2) may have blown.
The motor would have pulled more current when it was jammed.
Open the door up and check it with a meter, should be 0 ohms.
If blown be sure to use the new wiring harness that comes with it.
