Whirlpool Dishwasher wont drain water
My whirlpool dishwashe, model # DU890SWKT0, is not draining water. Wash cycle seems to be completing fine but the water stays in the tub, which might be causing the a sopy layer on dishes after drying.
I checked for clogs in the drain hoses connections and there were none. Any idea what might be the cause and recommend if any parts needs to be replaced?
Appreciate your help.
Praveen.
I’d be very interested in what you found out about your problem with your dishwasher. I’ve got a Whirlpool with the same problem…I’m thinking timer but not sure. Thanks!
