Brand: Whirlpool Model Number:WDT710PAHB1 Main Symptom: Dishwasher will not turn on
What happens & when: It shut off mid-cycle and is completly unresponsive.
Error Code (if any): No code bc the dishwasher is completly unresponsive
Parts or tests already tried: I checked for loose wires and for burns, I tried reseting the washer by using the interface panel, flipped the breaker, plugging the washer into a different plug, accessing the closure to determine if it was faulty, and I purchased a new control box from yall as this was the most likely problem identified but it did not work. The dishwasher is still unresponsive.
Hi there! Thanks for explaining everything you’ve already tried. You’ve done quite a bit of troubleshooting, and I can understand how frustrating it must be to replace the main control board and still have a completely unresponsive dishwasher.
Since your Whirlpool WDT710PAHB1 shut off in the middle of a cycle and now has no lights, sounds, or response from the buttons, I’d concentrate on two things before replacing any more parts: the power supply reaching the control board and the communication between the control board and the user interface.
Even though you’ve tried another outlet and replaced the control board, we still need to verify that power is actually making it through the dishwasher’s wiring.
Here’s what I’d check next
1. Check the power connections underneath the dishwasher.
First, turn off the breaker or unplug the dishwasher.
Remove the lower toe-kick panel and locate the electrical junction box where the dishwasher’s power cord or house wiring connects.
Check for loose wire nuts, overheated connections, damaged wires, or corrosion.
A connection can look fine from the outside but still fail internally, especially after heating up during a wash cycle.
2. Verify voltage reaching the control board.
If you have a multimeter and are comfortable checking live voltage, this is our most important next test.
With power restored, carefully check the incoming power supply.
Hot to neutral: approximately 120 VAC.
Hot to ground: approximately 120 VAC.
Neutral to ground: approximately 0 VAC.
If you have 120 volts at the junction box but not at the control board’s incoming power connection, we’ll need to trace the wiring between those locations.
If you have proper power at the control board, we can move on to the user interface.
Safety: Live voltage testing exposes you to potentially lethal electrical shock. Only perform these checks if you’re experienced and comfortable working around energized wiring. Otherwise, have a qualified technician perform them.
3. Inspect the user interface and its wiring.
Since replacing the main control didn’t help, the user interface (the button panel) becomes a stronger possibility.
With the dishwasher unplugged:
Remove the inner door panel to access the controls.
Locate the wiring or ribbon connection between the user interface and main control.
Disconnect and carefully inspect the contacts for corrosion, moisture, discoloration, or damage.
Reconnect everything securely.
Inspect the wiring where it passes through the bottom of the door near the hinges. Repeated door movement can sometimes damage these wires.
Whirlpool’s service troubleshooting guidance specifically identifies the keypad, its connections, and the control power connection as possible causes of a completely dead console.
Rev B
4. Check the door latch and switch.
I know you’ve already inspected the door closure, but I’d like to confirm whether you tested the electrical switch itself.
With power disconnected, use your multimeter to check the switch contacts for continuity as the latch is operated. Follow the switch’s wiring diagram to identify the correct contacts.
A faulty door switch can prevent operation, although a completely dark control panel makes the power supply and user interface higher priorities.
What the results tell us
Test result
What to investigate
No 120 VAC at junction box
Power cord, outlet, or house wiring
120 VAC at junction box but not at control
Internal wiring or damaged connection
120 VAC reaches control, but panel remains dead
User interface, wiring, or control compatibility
Door switch fails continuity test
Door latch/switch assembly
A couple of questions
Before you purchase another part, could you tell me:
Do you have a multimeter that can measure AC voltage and continuity?
When you replaced the control box, did you replace just the main electronic control, or did the replacement also include the buttons and display?
When the dishwasher stopped mid-cycle, did it go completely dark immediately, or did it stop washing first and then lose the lights?
Those answers will help us narrow this down. Since you’ve already replaced the main control, I’d especially like to verify power at the control and inspect the user interface before recommending another part.
