dishwasher turns on and off and now will not run for more then 1 minute, anythoughts from anyone would be appreciated. I think it is the electronic control assembly.
Could be a loose connection as well. worth a look.
Nat
connections look good. Any thoughts on the electronic control assembly
That would be highly probability. Do all the LED’s lilght up with you push the corrisponding button? If you have a ohm meter you should be able to use the tech sheet to do some tests.
Nat
will do, thanks for the help!
any time!
Nat
