This OLD dishwasher isn’t finished yet…but the pushbutton switch is. The part is no longer available anywhere so we want to bypass the switch. We don’t have the repair manual so we are trying to figure out the wiring. it has in the back of the switch top row a red and 2 white wires and the lower row is 2 reds and a white. It doesn’t look like there is a ground. Does anyone have any advice how to bypass the switch. All I need is the one speed in the cycle. Thank you in advance for any advice.
I cannot be of much help here as I cannot find any tech data on this particular unit.
The closest I can come is the following manual. See page 24. Yours is probably different but it should give you an idea as to how they wire the switch in.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56e33eb0e839a7fa85256a8e00510938/$FILE/4322430.pdf
The following may also be useful to you.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/86526067754822bf85256a8e00513d79/$FILE/4322481.pdf
[QUOTE=denman;325052]I cannot be of much help here as I cannot find any tech data on this particular unit.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/86526067754822bf85256a8e00513d79/$FILE/4322481.pdf[/QUOTE]
WOOOOOW!!! your my hero, I will get started on this and let you know. Thank you soooo much.
