I started the dishwasher the other night and when I checked to see if it was done since it got quiet, I opened it thinking it was on the dry cycle and noticed the water did not drain. I tried re-setting it (cancel cycle) to drain it and the LED lights were not coming on, it was not getting power. I checked the outlets and made sure they were working along with the main circuit breaker. All was good. I did some research and it said I need a new fuse…I am not sure if that is correct and if it is what this fuse looks like. Please HELP!![]()
Replacement parts for WHIRLPOOL DU945PWPT0 | AppliancePartsPros.com
The fuse is Item 4 in the “Frame and console” section.
Remove it and check it with a meter.
Not uncommon for these to go hence the kit with the harness.
Thanks! Can I take it to Home Depot or Lowers and test it? I don’t have a meter.
I do not know if they will test it for you!!!
I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
