Whirlpool dishwasher not cleaning top dishes
I have a GU1200 Whilrpool dishwasher that is not cleaning the top dishes - it seems to be doing pretty well on the bottom rack stuff, but not on the top. I have disassembled down to the chopper which was about 60-70% clogged and has 2 out of the 4 plastic drive teeth broken off. Do I need to go deeper into the disassembly? I don’t know the next step - I have the schematic, it says I can remove the wash motor and see the separator screen, but I don’t know if I even need to do this - help! Thanks!
35Cents,
Yes, I would go deeper,if I were you.
Based on your post, I’m pretty sure you’ll find the separator plate screen clogged as well.
You’ll need to replace the impeller assembly as well(broken drive teeth).
AP6048327
When you’re finished with that and you test the machine,
Let the dishwasher run approximately 3 minutes, unlatch the door,and wait a few seconds(20 - 30)open the door, and check the water level in the bottom of the tub, the water level should be touching the bottom of the heater element, if the unit is filling proper.
Low water level, will also affect the washability of a dishwasher, and spray arm operation.
Good Luck,
How hard is it to get to the separator screen? Do I have to pull the dishwasher out to do it?
35Cents,
No you don’t have to remove the dishwasher,
however, you’ll need to remove the pump motor, or if you wish, the pump assembly from the tub,
Based on your post, You’ve already done most of the work, But, I’ve attached excerpts from the service manual, to help you along.
[FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]The entire pump assembly can be removed from inside the dishwasher tub.
  1. Remove the access and toe panels from
    underneath the dishwasher door by removing
    the two (2) screws securing it to
    the dishwasher frame. [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]2. Disconnect the wiring harness connectors
    from the drive motor and pump motor
    terminals, the soil sensor and the thermistor.
  2. Disconnect the drain hose from the drain
    hose connector on the pump outlet.
  3. Remove the pump motor.
  4. Remove the three (3) sump tabs that
    secure the sump assembly to the dishwasher
    tub. [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]6. From inside the tub, lift the front of the
    sump up approximately ½ inch.
    Push the assembly back and then lift it out.[/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT] [/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=5][FONT=Arial][SIZE=5][LEFT]SERVICING COMPONENTS IN THE SUMP ASSEMBLY[/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=4][FONT=Arial][SIZE=4][LEFT]Removing the Wash Motor[/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]1. Remove the bolt securing the wash
    motor and drip shield in place on the pump
    assembly. [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]2. Once the bolt and drip shield are removed,
    turn the wash motor until it stops (approximately
    ¼ turn).
  5. Pull the motor straight back from the sump
    assembly. Some effort may be necessary
    to dislodge the motor. The volute will remain
    attached to the motor.
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3]NOTE: [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3]When reinstalling the wash motor and
    volute, do not pinch the volute seal between the
    volute and sump. Use a small amount of rinse
    aid on the volute seal to help installation.[/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][LEFT]
    [FONT=Arial][SIZE=4][FONT=Arial][SIZE=4]Accessing Components of the Sump Assembly[/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]Components inside the sump can be accessed without removing the sump from the dishwasher tub.
  6. Remove the four (4) screws securing the soil accumulator from the sump base. [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3]2. The soil accumulator will now lift free of the sump base.
    [FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]3. Remove the screw securing the foreign
    objects protector to the sump base and
    remove the protector. [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]4. Remove the screw securing the inlet protector
    to the pump base and lift the inlet
    protector out.
    [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3]5. Remove the chopper assembly from the
    impeller shaft and lift it from the sump[/LEFT]
    base.
    [FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]6. The check valve, located between the
    wash motor and the drain can be removed[/LEFT]
    with a pair of needle nose pliers.
    [FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]7. With the wash motor removed, the separation[/LEFT]
    screen can be removed from the sump base.
¼ turn).
3. Pull the motor straight back from the sump
attached to the motor. [/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][LEFT]NOTE: [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3]When reinstalling the wash motor and
volute and sump. Use a small amount of rinse[/LEFT]
Good Luck,
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
