Whirlpool dishwasher mod#WDT730HMAZ1 won't start, but when door is closed it will run whenever it wants
Brand:Whirlpool
Model Number:WDT730HMAZ1
Main Symptom:Won’t start
What happens & when:sometimes it will run whenever it wants to if the door is closed.
For your Whirlpool dishwasher model WDT730HMAZ1, the fact that it sometimes won’t start but then runs unexpectedly with the door closed points toward an intermittent electrical or control issue.
My first suspects would be the door latch switch, touch control panel, or main control board.
Here’s how I’d narrow it down before replacing any parts.
1. Check the door latch first
The dishwasher won’t start unless the control recognizes that the door is securely closed.
  • Open the door and inspect the latch for damage or anything preventing it from engaging.
  • Close the door firmly and see whether it starts.
  • Try gently pushing inward on the door near the latch after selecting a cycle and pressing Start.
If pushing on the door makes it start, I would suspect the door latch assembly or door alignment.
2. Check the Start button and control panel
Select a wash cycle and press Start.
  • Does the Start button respond every time?
  • Do the indicator lights change when you press different buttons?
  • Does the dishwasher beep or flash when you try starting it?
If the buttons respond inconsistently, the user interface control could be failing.
3. Reset the dishwasher
Turn off the dishwasher’s circuit breaker for five minutes, then restore power.
Select a Normal wash cycle, press Start, and close the door promptly.
If the dishwasher works temporarily after resetting but eventually develops the same problem, an intermittent control or wiring issue becomes more likely.
4. Check for Delay Start
Make sure the Delay Start option isn’t activated. A delayed cycle can make the dishwasher appear to start randomly when the programmed time arrives.
Whirlpool
What I would check next
If the door latch checks out, the buttons respond normally, and Delay Start is off, I would inspect the wiring connections between the control panel and main board before replacing either component.
One important question: When you say the dishwasher runs whenever it wants to, do you mean it starts an entire wash cycle by itself, or does it just start draining water?
That distinction will help determine whether we’re dealing with a control problem or a possible water-leak protection issue.
