Whirlpool dishwasher leaking water lower front door
Brand:Whirlpool
Model Number:WDT730HAMZ0
Main Symptom:leaks water center lower door
What happens & when:in the wash cycle
Error Code (if any):none
Parts or tests already tried:inlet water valve, washer sump assembly, lower spray arm, upper door seal, lower door seal.
Since you’ve already replaced the inlet valve, sump assembly, lower spray arm, and both door seals on your Whirlpool WDT730HAMZ0, I wouldn’t recommend replacing any more parts just yet.
A leak from the center bottom of the door during the wash cycle often points to water being directed toward the door, rather than a bad seal.
Here’s what I’d check next:
1. Check the lower spray arm rotation. Make sure it spins freely and isn’t hitting the racks or dishes. Even a new spray arm can cause trouble if it’s not seated correctly.
2. Check the dishwasher’s leveling. Place a level on the door opening and check front to back. The dishwasher should be level according to Whirlpool’s installation instructions, not leaning forward.
3. Inspect the inner door panel. Look for cracks, damaged areas, or loose screws around the detergent dispenser and vent assembly. Water can sometimes travel down the inside of the door and exit at the bottom center.
4. Check the water level. Start a wash cycle, let it fill, then open the door. The water should remain below the heating element. If it’s unusually high, we may have a water-level sensing issue.
5. Watch when the leak starts. Remove the lower access panel and use a flashlight to observe the area during operation. Be careful around live electrical components. Determine whether water is coming over the front edge of the tub or running down from inside the door.
One other possibility is excessive sudsing. Even a small amount of regular dish soap or rinse aid leaking into the tub can cause water to escape around the lower door.
Here’s what I’d like to know:
When the dishwasher starts washing, does water begin leaking almost immediately, or does it take several minutes?
Also, does the water drip straight down from the center of the door, or does it appear to run out from underneath the door panel?
Those two details will help us narrow this down to a spray-pattern problem, a door-related leak, or a water-level issue before you spend money on another part.
The leak starts when wash spray arms cycle and gradually leaks more as the cycle continues. It’s like water waves over the lower door seal within a few minutes at that point I stop the cycle. I ran the quick cycle with the door panel off and noticed the water waving over the middle part of the water tub. You mentioned the water level should be below the heating element. I stopped the quick cycle at one point and noticed the water level above the heating element. If the level sensor is fault? Is it easy to replace?
This job started out with the inlet valve wasn’t working. I got that replaced, it filled tub with water and started a quick cycle and immediately circulation pump hose was cracked and leaking water. Replaced the sump pump assembly with no more leaks from that area. Also replaced the drain pump as well. Then the door leak came to be. So I replaced the door seal and the lower door seal as well. I think you have something there with the leveling of the tub and water sensor. Thanks
Can you tell me what year this machine is?
Serial number FC1008155
It’s FC1008151. Thanks
this is a 2023 machine
You mentioned the tub water level that should be below the heating element and also the water level float and switch which turns off the water inlet valve these I will check for function. If the float switch is faulty why would the water shut off and cycle begin? Is the float switch assembly adjustable? Thanks
I’m surprised at the things went wrong with this machine for only being 3yrs old. However I look at all the hard water deposits and see how things can be destroyed from the inside out. Maybe next time a extended warranty.
That’s a very good question, and I can understand your frustration. Three years isn’t very long for a dishwasher to develop this many problems, especially after you’ve already replaced several parts.
On your Whirlpool WDT730HAMZ0, there’s an important distinction between the float switch and the normal water-fill operation.
1. Why would the dishwasher fill and start washing if the float switch is faulty?
The float switch is primarily an overfill safety device, not the component that normally determines how much water enters the dishwasher.
Here’s how it works:
  • The control board opens the water inlet valve for a programmed amount of time.
  • Under normal conditions, the float stays down and the float switch allows filling.
  • If the water rises high enough, the float lifts and activates the switch, interrupting the fill circuit.
  • The dishwasher can then continue into the washing portion of the cycle.
So, yes, the dishwasher can fill, shut off the water, and begin washing even if the float switch isn’t working properly.
A float switch stuck in its normal fill position may never interrupt an overfill. However, that doesn’t necessarily mean it’s responsible for your problem. A dishwasher can also overfill because the inlet valve allows too much water through or because the control isn’t managing the fill correctly.
2. Is the float switch adjustable?
No. The float assembly on this model isn’t designed to be adjusted to change the water level.
You can, however, check whether it’s operating properly.
With power disconnected:
  1. Locate the float inside the dishwasher tub.
  2. Gently lift and lower it to make sure it moves freely.
  3. Check underneath for hard water deposits or debris that might prevent movement.
  4. Access the float switch underneath the dishwasher and disconnect its wires.
  5. Check the switch with a multimeter for a change in continuity as you raise and lower the float.
A properly functioning switch should change electrical state when the float activates it. If it doesn’t, the switch or float mechanism may be faulty.
3. What I would check next
Since you’ve already replaced the inlet valve, sump assembly, spray arm, and door seals, I would concentrate on three things before buying another part:
  1. Water level: After the dishwasher finishes filling, open the door and check where the water sits. The heating element is a useful visual reference, but being above it doesn’t automatically prove an overfill. We need to determine whether the water is actually reaching the float.
  2. Dishwasher leveling: Make sure the dishwasher is level from side to side and front to back. If it’s tilted forward, water can collect near the lower door seal.
  3. Wash action: If the water level is normal, look closely at the spray arms and water movement. A spray arm directing water toward the door can cause leaking even when the seals are new.
Whirlpool identifies the float as an overfill protection device, and the model’s service information is available under tech sheet W11532444.
Whirlpool+1
Hard water can certainly contribute to mineral buildup and moving parts sticking, so your observation makes sense.
One question that would really help narrow this down: When you open the door immediately after the initial fill, before the spray arms start running, is the water already unusually high, or does it only begin coming over the lower door seal once the wash pump starts spraying?
That distinction will help us determine whether we’re dealing with an actual overfill or water being directed toward the door during washing.
