Whirlpool Dishwasher leaking bottom middle of door
Brand: Whirlpool
Model Number:WDF520PADM7
Main Symptom: Water leaking bottom middle of door.
What happens & when: water pushing out the bottom during filling, and washing cycles.
Hi there! Sorry you’re dealing with that leak. On your Whirlpool dishwasher model WDF520PADM7, water coming out of the bottom center of the door during both filling and washing can point to a few different issues. The good news is that we can narrow this down with a couple of simple checks before replacing any parts.
1. Check the lower spray arm first
One of the most common causes of water leaking from the bottom center of a dishwasher door is a damaged or partially blocked lower spray arm.
  • Remove the bottom dish rack.
  • Inspect the lower spray arm for cracks, especially along the seams.
  • Check the spray holes for food debris or buildup.
  • Make sure the spray arm turns freely and isn’t hitting anything.
A cracked spray arm can direct a strong stream of water toward the bottom of the door, causing water to splash past the lower door seal.
2. Check the water level
Since you mentioned that water pushes out during filling as well as washing, I’d definitely check for overfilling.
  1. Start a normal wash cycle.
  2. Allow the dishwasher to finish filling.
  3. Open the door and check the water level.
  4. The water should normally be below the heating element and should not be reaching the front edge of the tub.
If the water level is unusually high, check the float assembly inside the tub.
The float should move up and down freely. Food debris or buildup underneath it can prevent it from operating properly.
3. Inspect the door gasket and lower door seal
Check the rubber gasket around the sides and top of the door for damage, flattening, or areas where it has pulled away.
Also inspect the lower door seal and deflector area.
Keep in mind that the bottom of this dishwasher door doesn’t seal exactly like the sides and top. It relies partly on the door’s design to direct splashing water back into the tub.
4. Check for excessive suds
Even a small amount of regular dish soap or too much dishwasher detergent can create excessive suds.
These suds can push water out through the bottom of the door, especially during washing.
5. Check that the dishwasher is level
Make sure the dishwasher isn’t leaning forward. If the front is too low, water can collect near the door and increase the chance of leaking.
What I would check first
Because you’re seeing water come out during both filling and washing, I’d start by checking the water level and float assembly, followed by the lower spray arm.
One important distinction: If water is already leaking while the dishwasher is filling, before the wash motor starts, that makes a spray arm problem less likely.
I have two quick questions:
  1. Does water actually leak out while the dishwasher is filling, before you hear the spray arms begin washing?
  2. Is the water coming from the exact center underneath the door, or does it appear to be running down the inside of the door first?
Those two details will help determine whether we’re dealing with an overfilling issue, a door seal problem, or water being directed toward the door during washing. I’d rather narrow that down before having you purchase any parts.
How do I attach a video to show whats happenening?
  1. Lower spray arm is clean and free to rotate. No cracks and seam is tight.
  2. Water level is below the heating element after filling. Float assembly is clean and free to move up and down.
  3. I replaced the door gasket after we noticed water on the floor. There is no lower door seal on this model. What and where is the water deflector?
  4. I was running it with out soap and still leaking. Never saw soap suds on the ground when we first saw it was leaking. We use soap pods.
  5. Tried to check the level. Adjusted the washer legs up. Washer touching the upper mounting brackets.
  6. Water is hitting the inner door and water is shooting out of the inner door vents/ square holes and going past the inner tub behind the inner door while pump is running.
Ran the washer again after checking all the items you recommended and raised the washer using the leveling screws. Seems to be working and not leaking out the front. Water is staying inside and not shooting up the door to the outside like before. Will be ordering a new lower spray arm because the seam was open a bit so I used some zip ties to seal it. I belive that was one issue that water was being sprayed out at the middle seam. Also raised the washer some with the threaded legs.
You can email the video to tntechs@appliancepartspros,com
