Whirlpool dishwasher just went dead
In The Middle Of A Cycle Our Dw Stopped Working..did A Power Reset..nothing..did A Secquence Reset Also..nothing..tried To Review All The Blogs But Could Not Find One With This Problem On This Model…whirlpool Recommened A Service Teck But I Am To Handy For This..can You Help With-out Pulling Out The Unit As My First Step??..thanks
Here is the parts breakdown
Replacement parts for WHIRLPOOL DUL300XTKT0 Undercounter Dishwasher | AppliancePartsPros.com
I doubt that you will have to pull the unit.
Remove the kick plate and check that you have power to the unit
If OK and wire nuts are OK.
Remove the inner door panel and check the thermal fuse (Item 6 in Section 2).
If blown check for any signs of overheating/damage on the control board.
Be sure to use the new harness when replacing the fuse.
It is fairly common for these to blow on their own.
[quote=denman;308415]Here is the parts breakdown
There is a good STICKY at the start of this forum about it’s use.[/quote]
Thanks for the info. went into the box and found burnt connection and corrected it. Works perfect again. Thanks for the quick reply…
