No power to the washer at all-power supply is fine and I have ruled out the door switch parts.
Parts for Whirlpool GU980SCGQ2 Dishwasher - AppliancePartsPros.com
Could be that the thermal fuse (item 4 in the Frame and Door section) is blown.
If it is be sure to use the new harness that comes with the fuse when replacing it. Click on the parts picture for more info about it.
Could be that one of the door switches is bad or not closing.
Could be a bad connection from the power in point up to the control board.
Also may be a bad control board.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
15819990.pdf (483.5 KB)
[QUOTE=denman;796359]Here are your parts
There is a good STICKY at the start of this forum about it’s use.[/QUOTE]
Denman�� /|\ 8==D / \ �� ��
Just curious what the new wiring does with the thermal fuse. Mine popped twice in 3 months. The first time I said " these original connectors look fine, why cut perfectly good wires and scab on the new harness" so just replaced the fuse. Second time round I thought it best to read and follow the fine instructions. I have done that and so far so good. Back to my question, what does the new wiring harness do? Thanks so much for helping those of us with just enough knowledge to be dangerous. Ha. Your time and input is very much appreciated!
Sorry but I do not know.
