My whirlpool quiet partner III has power but all that happens is it flashes lights constantly they have been flashing for days. What might be the problem???
the lights on my dishwasher is blinking and does not work the only thing that works is the cancel button
kitchen aid dishwasher model kudsoiijalo control lock is on and dishwaser wont run. do i have to replace control panel? please sdvise pete.
What is the complete model number of the dishwasher?
Can you post more detailed description on the problem?
Did you try to turn the lock off by press and hold the Energy Saver Dry button for at least 4 seconds?
The model number you posted is incorrect. Verify and repost it together with the color of the control panel.
[QUOTE=Gene;287291]Did you try to turn the lock off by press and hold the Energy Saver Dry button for at least 4 seconds?
Gene.[/QUOTE]
the model number is DU1055XTPQ0 my control panel is white yes i did try to use the lock for 4 seconds on response
Very likely the problem is a bad control panel. White control panels have been discontinued by Whirlpool and only black control panel are available.
- The control panel AP6008252
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DU1055XTPQ0 Undercounter Dishwasher | AppliancePartsPros.com
