Tub won’t fill. Checked input water solenoid for power. Reading around 15VAC at the plug with plug disconnected. I am assuming the solenoid is the problem and have one on order from the site.
I hope I am right. Any idea what the voltage should be to this solenoid valve?
Solenoid should have 120 volts AC
Here is the wiring diagram
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208275137.pdf
Thanx denman! Searched some additional threads on similar problems and found some previous advise from you about the water level switch sticking which turned out to be my problem.
Thanx so much for your help. I am back out of hot water with the wife (or maybe actually back IN hot water, sorry a rather sad attempt at Dishwasher humor)!
Keep up the excellent work and forum.
ddunn81755
[quote=denman;50906]Solenoid should have 120 volts AC
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208275137.pdf[/quote]
That link to wiring diagram doesn’t work. Can you assist? Thanks!
