Whirlpool Dishwasher does not run at all
Hello, My dishwasher is not running at all. There appears to be no power to the control board due to no lights apparent. There is power at the socket and the washer is plugged in. I found a little water in the bottom from the final use. What can be the problem? Thanks, James
Check the ohms on your thermal fuse. Its with the circuit board in the top panel. If you dont get a reading that’s probably it. Always turn off the breaker in the fusebox before work. Good luck
