Whirlpool Diagnostic Sequence?
I have a Whirlpool GU2400XTPB6 with the dreaded :eek:“7 LED Flash”:eek: problem. Got this with the house when new, and (wouldn’t you know it) the datasheet is missing from the lower front panel.:mad:
I have validated the heater circuit from the control board, through the limit switch, on to the heater element, up to the door switch (I used a small wedge to simulate a door-closed condition to validate the microswitch), and back to the control board. Resistance throughout the circuit is approximately eleven (11) ohms (measured with the board disconnected between the WHT/RED Wire and the WHT wire after the door switch). :smiley:
First, is eleven ohms reasonable on this circuit? If this is not a solid measurement value, how much current should the heater element draw? I have an ammeter, and know how to use it. I could isolate the heater element and run 120VAC through it for a few seconds to determine current draw.
Second, is there any way I could get the diagnostic sequence from you?
I really don’t want to replace a control board & heater if the system sensed a low temp value and went to default.
Thanks!
Rob
Here is your parts breakdown
Model GU2400XTPB6
Here is your tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
Heating element is within spec. Draw would be 120/11= 10.9 amp.
