Brand:Kenmore Model Number: 110.82874130 Main Symptom: New transmission excessive noise part # 3360629 What happens & when: during the agitation cycle and when draining the water during the agitation cycle.
Error Code (if any): none
Parts or tests already tried: I have tried two new transmissions that were manufactured 6/2024 & 7/2024 both have the same noise issue. reinstalled old transmission and no noise. Old transmission just won’t spin.
B0th new transmission will go thru the rinse and spin cycle without the noise.
Does Whirlpool have a batch of defective transmissions built in 2024?
How can I get a replacement that was manufactured without this noisy condition.
Since you’ve tried two new transmissions (part 3360629) with the same excessive noise, and reinstalling the original transmission eliminates the noise, I would strongly suspect an issue with the replacement transmissions rather than the washer itself.
The fact that both new transmissions were manufactured in June and July 2024 certainly raises questions about a possible manufacturing issue. However, I wouldn’t conclude that Whirlpool had a defective batch without confirmation from the manufacturer.
Here’s what I recommend before ordering a third transmission.
Check the agitator and drive components. Make sure the agitator is properly seated, the mounting bolt is tight, and nothing is rubbing against the transmission or agitator shaft.
Run a short agitation test. If possible, test with the washer empty. Listen for grinding, clicking, or gear chatter. A little mechanical noise is normal, but loud grinding or knocking isn’t.
Compare the old and new transmissions. Since the original transmission agitates quietly, this is a particularly useful comparison. Check for differences in shaft movement, excessive play, or binding.
Document the manufacturing dates. Keep the date codes from both replacements, along with a recording of the noise. This information will be useful when requesting another replacement.
One important detail: On this Whirlpool direct-drive design, the transmission is responsible for agitation and spin, but the drain pump is driven separately by the motor. If the noise occurs during the drain portion of the cycle, we should also verify exactly when the transmission is being driven.
I also found other owners reporting very similar excessive agitation noise with replacement 3360629 transmissions, including reports involving multiple new units. That supports your concern, although it doesn’t establish a confirmed 2024 production defect.
Appliantology
+1
For getting another replacement, I recommend contacting the supplier you purchased from and requesting a warranty review or exchange. Ask whether they can check the manufacturing date before shipping and provide a unit from a different production lot. They may not be able to guarantee a particular date.
One question: Is the noise more of a loud grinding or gear-chattering sound, particularly during agitation and the initial drain before the washer starts spinning? That would help narrow down whether we’re hearing the internal gears or the neutral-drain mechanism.
