Whirlpoo Dryer
:confused: IWANNA KNOW HOW I CAN INVERT THE COURENT FROM 240 VOLTS TO 110 VOTS COUSE THATS THE VOLTS RUNING IN MY BULTDING
Hi Baltazar
If you do not have a 240V outlet in the laundry room your options are: to have a professional electrician to install such outlet or to use a gas dryer which needs only 120V.
