Whirl Duet Front Load Washer fault code F11
Whirlpool Duet Front Load washer displaying Fault Code F11 intermittantly and washer shuts down
F11 = Serial communication error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
