Whilrpool Dryer LEB6300PW0 Timer would not work and No heat
Brand: Whirlpool Dryer
Model Number: LEB6300PW0
Main Symptom: Timer does not advance and No heat
Timer has 3 settings, Automatic Dry, Timed Drying and Fluff Air.
Only the Timed Drying that you could hear the timer running BUT still no heat.
If you access where the power cord connects to the appliance, does the terminal block measure 240 Volts AC when testing from the red wire to the black wire with a multimeter?
