Which part do I need? I'm getting a E09 error code on my Bosch dishwasher. It runs but doesn't not appear to heat
Brand: Bosch
Model Number: SHXN8U55UC/06
Main Symptom: not heating, error E09
What happens & when: Runs and washes but does not heat.
Error Code (if any): E09
Hi there! Thanks for providing the model number. On your Bosch dishwasher SHXN8U55UC/06, the E09 error code indicates a problem with the heating circuit. Since the dishwasher still fills, washes, and drains but doesn’t heat the water, the most likely problem is a failed heating element inside the heat pump assembly.
On this Bosch model, the heating element is built into the circulation pump ( Bosch 00753351 Dishwasher Circulation Pump With Heater | Genuine OEM Part) rather than being a separate exposed element at the bottom of the dishwasher.
Here’s how I would troubleshoot it.
1. Try a power reset first.
Turn off the dishwasher’s circuit breaker for about 5 minutes. Restore power and run a wash cycle. If E09 returns and the water remains cold, you’ll want to check the heating circuit.
2. Test the heating element.
  • Turn off the circuit breaker before accessing any electrical components.
  • Remove the lower access panel to reach the circulation pump assembly.
  • Locate the heating element connections on the heat pump.
  • Disconnect the appropriate wiring connector.
  • Using a multimeter set to resistance (Ω), measure across the heating element terminals.
A working Bosch heat pump heating element commonly measures approximately 15–25 ohms, although the correct specification should be confirmed for the installed pump.
If your meter reads OL or infinite resistance, the heating element has failed and the heat pump assembly will need replacing.
Also check for any burned or damaged wiring connections.
3. If the heating element tests good:
The next step would be checking the wiring between the heat pump and the main control board. A damaged connection or a failed heating relay on the control board can also prevent heating.
I would not replace the control board until the heating element and wiring have been checked.
What part is most likely needed?
For your Bosch SHXN8U55UC/06, I would suspect the heat pump/circulation pump assembly first. The heating element is integrated into this assembly, so a failed element generally means replacing the complete pump.
The exact replacement part number should be verified against your model’s parts diagram before ordering.
One quick question:
Do you have a multimeter available to check the heating element resistance?
If so, I can walk you through accessing the heat pump and identifying the correct connections to test. That should help us determine whether you need the pump assembly or whether the problem is elsewhere in the heating circuit.
Thanks for the quick reply. We have tried unplugging the dishwasher, restarting it and running a cycle with no luck. Unfortunately I do not have a multimeter. I guess I’ll try replacing the pump assembly if that is the most common solution.
