Dishwasher packed in a month or so back, read that the fact it has water still in the bottom, didnt complete the wash cycle, and that it wont power on, means that more than likely the thermal fuse has gone, tried to find it by the control panel but had no luck.
Can anyone please help?
OK now I get it.
This is a UK machine
Unfortunately I cannot get any info on this unit as this is a US based site.
Tried to cross match it to a US unit but had no luck
Could be a door switch is not making correctly. Try pushing the door in a little.
On North American units the thermal cutout is often at the end of a 2 wire harness which connects to the control board.
Also check the wiring hook up, if hard wired it could be a wire nut was not installed correctly
