Where is tumbler located?
my dryer quit tumbling, but still heats up. i need to know how and where tumbler is located or if it has a belt?
Hi.
The term “tumbler” means - the drum. If you can hear the motor running but the drum isn’t turning, then most likely the belt needs to be replaced.
The belt AP2946843
Here are the breakdown diagrams and Replacement parts for Crosley CDE6500W DRYER- ELE | AppliancePartsPros.com
Good luck. If you will need any help - just ask.
Simon.
