The repair manual says the fuse is either under back burner left or front burner right but it is not under any burner anywhere, so where might I find it. My stove is double oven unit and I blew a fuse so the timer and clock don’t work.
There are no fuses used in this range. Check if 120 VAC is coming to the clock?timer motor. If there is proper voltage, the clock has gone bad. Unfortunately this part has been discontinued and is no longer available.
Here are the breakdown diagrams and Replacement parts for General Electric JHP67G*D1 Hi-low range | AppliancePartsPros.com
