I think the fill valve on my KA DW KUDS01DJSS0 needs replacing. I can find the part on line. Can you point me to something that tells me here is the valve and what are the steps to access and replace it? Thank you.
Turn off the water to the dishwasher and unplug the power cord. Remove the toe panel and you’ll see the water valve on the left side. Disconnect the water line from the water valve and remove the valve.
- The part number for the water inlet valve is AP3178609
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDS01DJSS0 | AppliancePartsPros.com
Thank you, Gene.
Bruce.
You are welcome, Bruce. Keep us posted.
