Where do I find the motor and belt?
Greeting everybody! My dryer heats up, but it’s not spinning anymore. My guess is that there must be a problem with the belt. I opened the back but I couldn’t find the access to the motor or belt… Do I get to them from the front? If somebody could tell me where and how to open it to find this parts I would be really grateful. Thanks!
You have to go into the front. Remove the filter and the 2 phillip head screws. The pop the top up. Then take the front off. There will be a 5/16s screw on the left side, about 6 inches down, and one on the right side, and then grab the front, and pull up on it to remove the bottom of it from the cabinet. Then remove the wires from the door switch, and then you are there. Tom ApplianceEducator.com
