When dryer is on sounds like drum is off balance runs rough
Brand:
Model Number:
Main Symptom:
What happens & when: When dryer is on sounds like drum is off balance runs rough
Hi MosheMehlman,
Could you provide the model number of your dryer?
Also, can you describe the noise a bit more?
  • Does it sound like a steady, rhythmic thumping, almost like the drum is dropping at the same spot each rotation?
  • Or is it more irregular or rough-sounding, changing as it runs?
That detail will help narrow down whether the issue is related to something like drum support components, rollers, or something out of alignment. Let us know what you’re hearing and we’ll go from there.
