What part do i need?
Dishwasher is out of warranty. It runs, but the touch pad will not let me delay or change cycles… It is stuck in one mode… only two green lights work on the display… I bought the electronic circuit board but I think I need something else?:smiley:
Here is the parts breakdown
Replacement parts for mdb7751aws1 models | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16026394.pdf
The usual way to troubleshoot these units is:
Unplug/remove power from the unit for 10 minutes or so to see if the control board will reset.
If this does nothing.
Try running diagnostics to see if it will give you a clue as to what is going on.
If this brings no joy
Unplug the unit and check the keypad with a meter to make sure all keys are opening and closing.
If it checks out OK replace the control board. Still a bit of a crap shoot but your odds are better.
If it has problems replace the keypad.
You may also want to try the below.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Hi do you have a new link that works. Or can you email me the service manual. How do I get to the control display?
Thanks for the info
[QUOTE=denman;281928]Here is the parts breakdown
Unplug the unit
Open it up
Reconnect everything and give it a try.[/QUOTE]
