The water valve is getting 122 VAC. However the valve reads open, no resistance. Therefore, I ordered a new valve from APP. This valve also read open. APP Customer Service said I needed to install the valve before I would get a resistance reading. The new valve still reads open after installation. Please help.
Since the valve is opening for 30 seconds it sounds like it is getting proper voltage, at least for 30 seconds. From looking at the cycle chart, that is about right. Seems like something is keeping it from proceeding further into the cycle. I don’t think it is the inlet valve.
With that IE inlet error I would be suspecting the flow meter AP4457564 on the water inlet guide AP4442244 is bad.
If that flow meter isn’t seeing water moving it’ll give that IE code. That’s the part I’d be most likely to replace.
Thank you Rory. I really appreciate your response! The first thing I replaced when this problem started was the Flow Sensor. LG part # 6501DD2001A. I believe that is the same part as AP4457564.
