WCVH6800J1WW Starting a cycle just triggers the drain pump and after 3-5 minutes the pump stop and the start/stop button is blinking
Brand: GE
Model Number: WCVH6800J1WW
Main Symptom: Drain pump runs at start of cycle for 3-5 minutes and then start/stop is blinking
Error Code (if any): E54
Welp, my trusty washer has finally stumped me. I have a GE WCVH6800J1WW, and it does not want to wash laundry anymore. I was doing laundry and went to start the next load when it did something odd. It started like it normally does; it locked the door and did a short drain cycle to make sure the washer was empty. However, it ran the drain pump for about 3-5 minutes, and then the Start/Stop button was blinking with the door still locked.
This is the first time I’ve seen this before, so I started looking online as to what the culprit could be. The first guess was that there was a clog in the drain, so I opened the port at the bottom, and it did have some water in it, but nothing major. So, once it was dried out, I tried to start the load again and got the same result; the drain pump ran for about 3-5 minutes and then stopped with the Start/Stop button flashing. I also tried to blow out the drain pipe with the same results.
So my next idea was that the pressure switch and tube might be clogged, so I opened the machine up and blew air down the tube, toward the washer, not into the switch, and there is very little resistance. From there, I also tried to flush the line with some warm soapy water, in case there was something in the air dome, it flowed right through. After this, I tried to run the cycle again and got the same result.
Now, I tried to pull the pump and make sure there was nothing stuck in it directly, and also gave it a quick test. Upon opening the motor and drain assembly, there was nothing in the pipe or adhering to the impeller. The impeller does give a little resistance and then flips to its next “spot”, which seems normal for this type of motor. I also tested the leads to the motor and got about 11-12 Ohms. Which, from what I read, is fine.
Now, I got the device into diagnostic mode, and there were 3 different error numbers in the list: 23, 54, 60. Now, I do not know if they are all current, so I reset it, and am now getting just error 54. From what I see online, this is possibly the motor or the inverter. Apparently, if they are bad, it can cause the washer to try to drain and then stop. To that end, I took my multimeter and pulled the motor and inverter. I tested the three leads and saw about 6 Ohms between each of the leads (1->2, 1->3, 2->3), and none of them are showing continuity when I connect the lead to the metal casing of the motor. So, that seems to be all in order.
Next, the inverter, the two major caps look fine and are registering as an escalating resistance (ohms) when tested. I’m not seeing any scorch or burn marks on the board either.
Finally, I took a look at the main control board, and it looks fine as well.
Anything I’m missing here? What step would be next to try to fix this? Replace the inverter?
While the motor may have proper resistance, you will want to do a voltage test to make sure that there is between 102 and 132 vac. Check the connections at the motor, the harness between the main control and the motor. If this is all ok then clear the code and if it comes back again then this will be a faulty motor.
WCVH6800J2MS-31-16559-1.pdf (272.9 KB)
This was indeed the inverter, replaced it and all is working. Cheers for the reply
