Water wil not drain from dishwasher
I just replaced the control panel on this Whirlpool Quiet Partner IV Dishwasher with a part from Appliance Parts Pro.com because it would no longer run any wash cycles. Now after the first new cycle completed, there is water sitting in the bottom of the dishwasher, and the “Cancel/Drain” button will cycle through from 2 down, but it does not drain the water. The “Cancel/Drain” button on the old Control Panel was the only button that did work before it was replaced. Now this function is not working. Thoughts?
Replacement parts for WHIRLPOOL GU1500XTKQ0 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208533399.pdf
Could be the part you received is defective.
Check it with a meter.
If OK, clean the connectors and give it a try
Could also be a broken loose wire going to the pump.
Could be the pump is shot.
Meter
CONNECTOR CLEANING
Unplug the unit
Open it up
Clean the edge connector.
