Water Not Pumping Into The Manifold
The check valve is on the right side of the chopper, a black thing stuck in the housing
Read more: http://forum.appliancepartspros.com/dishwasher-repair/2903-whirlpool-dishwasher.html#ixzz1abHJ3SMR
Gene , are you talking about the chopper cover or the slot that the right side of the chopper cover fits into. I have no black rubber anywhere so I can’t tell where un it goes:(
The following is the picture of the check valve.
I know what the check valve looks like. I just do not see anyplace where it goes:mad: I believe mine got eaten up so I need to know where to instal the replacement. There seems to be nothing to the right of ther chopper assy where it might go
Check the attached document.
Check valve.pdf (45.8 KB)
:eek: Well, I now have replaced the chopper assy and check valve. Still does not work. Every two weeks I have to clean the chopper screen because it is totally plugged up on both sides. Is the only thing left that could cause this, a non working impeller.Is there any way to check to see if it is working? Wouldn’t I need to acess from the bottom to replace?
The same ongoing problem after the chopper has been replaced means the impeller is bad. Whirlpool does not sell it separate, so you have to order the whole new motor assembly. The instructions are attached to the reply.
GU1200XTKQ0 tech sheet.pdf (1.1 MB)
