water level pressure switch
Is the water level pressure switch on Frigidaire top load washer FTW3011KW0 adjustable? The washer has never filled up.
Generally it is a bad idea to try and adjust these even if they are adjustable. Go ahead and replace it because if it fails your house can be flooded.
