Water leaking under door...need to know how to remove door & replace seal
Water is leaking under the door. I need a manual or picture to show how to remove the door of the dishwasher and replace lower seal.
First i would check spray arm for cracks and make sure all screws are tight on pump housing. You also have adjustable latch.
