Water leak from seninoid area
when the solenoid operates to remove the water, a leakage is present at the base of the solenoid. other then this the dishwasher works as expected. the water is not from the solenoid ,what is faulty and is it repairable? what parts should i change. thank you:mad:
Water leaks through the drain valve shaft seal (#417 on the diagram). The seal has to be replaced together with the push-on nut. You have to remove the dishwasher from the cabinet and carefully lay it down on its back.
Here are the breakdown diagrams and Replacement parts for General Electric GSD3330C05WW Dishwasher | AppliancePartsPros.com
